Narp! Corsa front coilies and polo rear coilies is common for slammage. Polo fronts are less commonly used (but growing in popularity) and corsa rear dampers are used with cut springs but that's not coil overs...
Easy enough to do lol. We can't, use corsa rear coilovers very well cause they're separate spring and shock but the spring is egg shaped and catches on our mounts/has wrong diameter. And people lean away from polo fronts cause of the modding on the lower mount.
Ah well you see micras have a 10mm difference in hole mounts. Whereas scooby has 4mm considering using those
A. Its a coil over
B. I havent got to rebuild strut towers
