Polo 6n2 front wheel bearings
My friend has asked if I could have a look at her car, needs two new wheel bearings and mid section of exhaust. The exhaust is ok just not fun by the side of the road.
Has anyone done the bearings? Are they easy? I believe they are sealed bearing units is it a case of removing a circlip and hammering out the bearing from the hub?
I have done the rears on a fiesta before, took a while but fairly easy.
Matt
if its like the audis, you will have to press out the abs hub and then press the bearing out and back in. they arent that bad IF you have a press but just be careful of the abs sensor aswell
