Please help with Air con
Hello every one,
I have noticed that my air con is not working. The Haynes manual does not say anything about it.
Can some one tell me please what might be wrong with it and how to repair it if possible?
Regards
I always got the impression that you shouldn't really touch the air-con system as it's a specialist bit of kit :oops:
(Refrigeration unit and nasty chemicals inside)
my mum's aircon (on her K12) has never worked right...
she had it "Re-gassed" at £50 a pop, and it worked for almost a month before failing again
...she took it back to check for leaks and none were found so they just topped it up again...for another £50 <_< ...and it worked...for about a month...
We think it needs a new compressor...which none of our local garages can seem to source so we have to take it to Nissan
....gonna cost around £400 for parts and labour... :rolleyes: although one of the garages that tried to get the part for us quoted £300...so £400 don't sound that bad?... *Facepalm*
...so glad there's never been an issue with mine... ^_^
I hope your simply needs re-gassing... (K11 right?) ...could just be getting old? ;)
Very many thanks,
Yes probably it needs regassing. I will not touch for a while now.
Regards
You may have a leak in the system, best bet is to take it for a proper aircon service, they will vacuum test the system add a uv dye and look for any leaks. You cant do this yourself... And dont be tempted to use the aerosol cans you can buy for a/c as they contain gasses that are far from ideal.
