CMF_lewy_b
» CMF MemberHi everyone,
Just wondering if anyone can help with a problem im having with my K11 Micra (cg13)
The car starts up and is drivable until it reaches normal engine temp. Then at the revs start dropping (usually completly fall), and then after a few seconds start picking back up and just goes on like this, and car is undrivable,
Thought might have been problem with ignition system (i.e plugs, distributor etc. So replaced the plugs, the distributor cap, rotor arm and done the timing but still have the same problem.
Dont know if its maybe something like throttle / idle release valves? Dont have manual and not to sure about the engines.
Any1 got any ideas would be much appreciated
