Please help me
Need help please guys I've took my throttle body off everything's the same apart from the new throttle body doesn't have a pipe at the front (looks and tastes like coolant)
Can I by pass it with abit pipe.
My cars 2000 coilpack
And new coilpack a of 51 plate coilpack
NEW
image-jpeg.45410
Mine
image-jpeg.45409
ur old TB had this ancient coolant driven waxstat fast idle cam mechanism,
which tends to seize open with age and which I always advise ppl to remove via here https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446256
the modern IACV at the front also does the same job.
on the newer facelift coilpack TB, nissan prob leant bout the faulty waxstat and removed it, leaving the IACV (moved to the rear) to do all the idle control.
so to answer ur Q, the old TB coolant lines can be bypassed or simply plugged up cos it runs parallel to the coolant return route.
I got the throttle body of a engine that was running sweet as. Put it on my car a it made it surge bad and idle at 1800-2000 were as the old one idles at 800.
I've put old one back on.
Do you know why this could be or what i can do @pollyp
