Hi everyone!
I'm looking around to get things done on my car, and something i should change are the spark plugs.
I'm not getting misfires and all that, but i had to bump all them when i changed the oil because the separation was more than it should, so i noted i shiould change the spark plugs.
I've been looking, and as far as durability is concerned, platinum spark plugs are a nice middle ground between standard plugs and iridium plugs, and as long as i can tell, they will probably last some years before i have to think about them again if i have to check anything.
The thing is, what should i look when i buy them? I know my engine is CG13DE, but isn't like it's written on the plug, so i don't really know what i should install. Or should i go for factory plugs?
I'll listen to you all...let's see what we get.
Thanks.
Thanks.
