Ok so basically I ordered some for the cg10 and they refunded after a few emails as they didnt have them in stock at best parts store so I had anpther look on ebay and the one that were the right year said they were fpr 72.5mm bore iirc not the 71 that the haynes manual says coildnt find any that were the right size but then I found some on ebay with the wrong yr (said for 83-93) and wrong engone code ma10 I think it was but the right size bore so I just ordered them yesterday taking a £50 gamble
They arrived today which was quicker than expected so ive took number 4 pistons rings off to compare. The top 2 are both very similar but a wider gap at the split so ill check them dimensions with haynes but I think they will be good but the oil scraper is a different design.
Only slight as the sizes seem to match up but the waves go in and out (along the radius of the piston) wheras the standard ones go up and down (cam to crank)
Cant see the scraper making much difference as it doesnt have to seal it but will it be ok to use? I imagine it has some benefits or somat, possibly less likely to get clogged with crud?
What you reckon peeps
