Pcv valve
Hi just bought my daughter a 1.2 to learn to drive in it is using a bit of oil After reading some posts on the forum I am going to change the pcv valve does anyone know the part number and where to buy cheers for any help
1181041B02 is the part number. The service manual mentions that you have to change the gasket if you're "poking" around the area (part no. 1181241B00). I bought them from amayama (the delivery time is about 2-3 weeks and they're genuine).
Some people just clean the valve with carb spray cleaner or such. (It's just a piece of plastic inside another piece of plastic)
The crankcase ventilation system PCV valve can be simply serviced by removing it & soaking overnight in a cup of diesel or petrol to degrease/de-sludge it & ensure that its corresponding CVS filter, fumes pipes & orifices are clear & not blocked.
I have never seen a PCV valve fail in 45 years of motoing, PCV just needs servicing every few years.
Said condensate oily sludge in the fumes galleys are a characteristic of an oil burning badly worn engine.
References: https://www.google.com/search?client=firefox-b-d&q=Define;++pcv+valve+
http://www.agcoauto.com/content/news/p2_articleid/197
Good luck
