Hi, the passenger window has just stopped working on my Micra 66 plate, the drivers side works fine.
Does any one know what may have gone wrong? Are there seperate fuses for left and right?
I had that problem. In my case, a small spring inside had dislodged and was jamming the switch. I just removed the spring and the window works now without the spring. Or, you could try a new switch, about £5 on fleabay or try your local car breaker.
