Passenger external door handle broken
Hi all..
I have a 53 plate Micra.. the other day I pulled the handle on the passenger side and the whole lot came off in my hand.
Ive managed to put it all back together and nothing looks broken.. but I cant see what holds the smallest bit in (the bit with the rod on the back)
Do I need a complete new handle? Is there a how to guide on here about fitting?
What holds the smallest section in place?
Regards
Allan
On the inside edge of the door, a couple of inches above the latch, is a plastic grommet (or hole if someone's removed it). Within that hole is a torx screw (t30 I think, maybe t27) that holds that part of the handle in place (the same but that include the keyless entry button where fitted).
Hopefully the screw I still in place, and you'll just need to tighten it.
