Parts list for Micra
Hi,
I enclose the following info as a number of members are struggling with what parts can fit the K12. hope the information is helpful.
Nissan Micra (K12) 1461cc Diesel 63Kw (86BHP)
Engine Code K9K 276
Front brake discs:- 40206-AX600 (260mm Dia x 22mm thick)
Front brake pads:- 41060-AX625 (12.40 mm thickness)
Front brake caliper RIGHT:- 41001-AX601 (brake system TRW)
Front brake caliper LEFT:- 41011-AX601 (brake system TRW)
Front brake carrier (LH & RH) 7701059704 (Renault)
Front brake caliper Piston:- 41121-AX601(piston Dia 54mm/height 53.6mm
Front brake pad spring kit:- 41083-AX625
Front brake flexi hose:- 46210-AX606 (or AX601) ( length 615 mm )
Front brake banjo bolts:- 463560-E00A-----M10 x 1 x 22.8mm long
Front brake banjo sealing washers:- 46237- A4600
Front brake flexi hose retaining clip:- 462062 - J00A
Front wheel bearing:- 40210 - AX000---ID 37,-OD72.1 -width 37mm
Renault 7701207677 (alternative)
Wheel Bolts 40222 - BC 40A (Renault 7700835830)
Length 51mm, M12x1.5 60deg seat angle, 10.9 strengh thread length 25mm, outer dia 23
Front outer CV joint 39211 AY625 ._ Blue print :- ADN 18941B, (Dia 83mm - height 143mm,Seal Dia 49mm, Ext Teeth 23, Internal Teeth 22).
Front Drive Shaft (RH) 39100 AY600 - Length 894mm inner spline 26
Front Drive Shaft (LH) 39101 AY600 - Length 647mm inner spline 26
Seal Dia transmission side 79mm
Front tie rod end:- 48520 - AX602 (right) :- 48640 AX602 (left)
Mapco - 49136 (right) :- (49135 left)
Front tie rod inner (same both sides) 7701475841 (Renault code) L323,H36,W36
Front steering rod boot kit:- 48203 - AX600 or 7701475840 (Renault)
Front bottom ball joint :- 40160 - AX600
Front lower wishbone (RH) 54500 - AX600
Front lower wishbone (LH) 54501 - AX600
Front upper support arm (RH) 54524 - AX600
Front upper support arm (LH) 54525 - AX600 (54525 - BC01A)
Front Axle Drop Links 54618 - AX600 (or 54618 - 9U00A) Length mm Thread Dia 12mm (uprated from 10mm)
Front wheel spindle knuckle arm (LH) 40015 - AX600 (8200345944 Renault)
Front wheel spindle knuckle arm (RH) 40014 - AX600 (8200345945 Renault)
Front shock absorber (RH) 54302 - AX626 (Strut length 513mm, piston diameter 20mm, travel length 346mm, Shaft Diameter 45mm.
Front shock absorber (LH) 54303 - AX626
Front coil spring 54010 - AX602 (L-353, thick 11.5, OD 142mm
Front suspension top strut & bearing 54320 - AX600 (RH)
Front suspension top strut & bearing 54321 - AX600 (LH)
Front shock absorber dust cover 54050 - AX601
Front spring lower rubber pad 5306018 (ford “S” max galaxy edge fits!)
Front wheel flange 40204 - AX600, 23 int splines (Mapco 26155)
Engine mounting rear 11360 - AX600
Front Anti-roll bar stability bushes 54613 - AX602 (ID 20.5mm)
Front Headlight (Left side) 26060 BC01A (or 26060 - AX705)
Front Headlight (Right side) 26010 BC505
Front Airbag Crash Sensor 98582 - 9U00A
Engine sump plug M16 x 1.5 (12.5mm long / 8mm square drive)
Engine crankshaft sensor 22630 - 00QAG (Renault )
Engine Diesel Fuel Filter 16400 - BC 40A (Renault 82 00 026 237)
Pollen filter (cabin) 27891 - AX010
Engine coolant hose (long front) 1405300 - QOB
Engine Exhaust mounting rubber 20651 - AX610
Engine Air filter 16546 - BC 40A (Renault 8200216005)
Rear brake drum 43206 AX650:- or (7700428821 Renault)
Rear Wheel bearing 43210 AZ300:- or (7703090253 Renault)
Dimensions: OD 52mm, ID 25mm, width 37mm
Rear drum brake shoes 44060 - AX625 (203mm x 38mm)
Rear suspension springs 55020 - AX601
Rear spring seat rubber (top) 55034 - AX600
Rear spring seat rubber (bottom) 55032 - AX601
Rear shock absorber 56200 - AX602
Rear shock absorber dust cover 55240 - AX600
Rear drum back plate (R,H) 8200896145 (Renault)
Rear drum back plate (L,H) 8200896142 (Renault)
Rear hand brake cable (R,H) 36530 AX601 (1604mm length)
Rear hand brake cable (L,H) 36531 AX601 (1540mm length)
Rear hand brake cable Centre 36402 AX000
Rear brake piston 44100 AX600
Rear brake flexi pipe 46214 - AX600 (303mm Long)
Rear Brake Shoe Adjusters 8200276843(Renault)
Hi,
Engine Code K9K 276
Thanks. Very useful.
Sent from my LYA-L09 using Micra Sports Club mobile app
