parrot MKI9000 and double din cd player
Vitus992
Would like to get the parrot MKI9000 in my K12, it has the double din 6 cd changer, is this a "reasonably" straight forward job or is this best left to "them that know". Thanks to the great tutorial on http://www.micrak12.com/radio.htm I have no worry about accessing the head unit but will I be wrestling a mile of cabling?
Just a final note on this, I opted for a parrot CK3000 evo in the end. Very straightforward instalation thanks to Guys radio removal tutorial. You do not need any additional leads with the double din unit, its all ISO plugs so no problems at all.
A final update - you need to swap the two power leads fuse holders around otherwise the control unit stays on all the time. Apart from that its a 30 minute job.
