Hi people,
Recently managed to get one of them parcel shelfs with the nissan 6x9s for free!
However, when there is a lot of bass, the speakers rattle quite a lot. I figured it was something inside one of the speakers and so opened them up, cleaned them up and surely found a loose plastic piece and removed it.
Problem is still there although a bit quieter.
A bit of research showed that it is just resonance of the parcel shelf and other things surrounding the boot.
Anyone else had same issue and how did you fix it? Ideally I am looking for a smart and cheap way to sort this issue out. I would like to see some pics of peoples set ups, I've looked into dynamat (sound deadening insulation stuff) but seems very expensive and anyone tried it? Does dynamat work?
