CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 28, 2014 #1 Hey people just quick question does any one know the width of the parcel shelf in cm I want to install led lights along it . Thanks
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 28, 2014 #3 The actual width of it at the bottom its micra k11
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 28, 2014 #4 Bottom of it the whole shelf
CMF_AB-NRML » CMF Member Perth, WA, Australia Member since: Posts: Jan 28, 2014 #5 I'll go have a look...
CMF_AB-NRML » CMF Member Perth, WA, Australia Member since: Posts: Jan 28, 2014 #6 Okay, 880mm should give you a nice flat surface to mount your lights. Its about 900mm wide but the radius on each end may cause problems if you are sticking them on with double sided tape or similar.
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 28, 2014 #7 I want to put them there
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 28, 2014 #8 Can you upload a picture of where you mesured please Attachments 87512.jpg 94.7 KB · Views: 32
CMF_AB-NRML » CMF Member Perth, WA, Australia Member since: Posts: Jan 28, 2014 #9 I can't upload pics, pic size on the phone is too big. I measured the flat part top to bottom as your pic shows
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 29, 2014 #10 Any idea what this is its some sort of chip
CMF_jordan donohoe » CMF Member Ireland Member since: Posts: Jan 29, 2014 #11 Do you know what the blue thing is at the back of the clocks its like a chip with a 4 pin block
