Parasitic Draw
The battery seems to be draining a bit faster than it should when the car is parked up. It would probably go flat after about 10 days of no use.
According to my multimeter it's drawing around 80mA with nothing on that I can see, except the immobiliser and radio LEDs flashing.
I suspected it might be the radio, so I removed the audio fuse. This stopped the radio working but the LED still flashes. What fuse to you need to remove to stop this? According to the owner's manual the LED should stop flashing after the car has been started, but mine flashes all the time. Possibly a fault there?
