Any suggestions welcome for removing my panhard rod!
So far i have removed it from the body side of the car, and removed the nut on the axle end. now however the metal insert in the bush is firmly siezed in place. I've tried hitting it, bending it, hitting it again, used a ball joint remover on it, covered in WD-40, welded the end of the stud for heat, and used a number of chisels to free up the insert round the back. I'm now rather at a loss....
