Is it 18mm on the body and 15mm on the axle?
The way I was thinking Frank is that if I used the same size joint as the existing bolt, they would be as strong as the existing fixing. Though the bolts in shear would probably actually have to be thicker for the same strength than the joint in tension, I think.
