hi,
Apologies for asking for help on the first post, my other half has a 2003 k12 1.2 micra.
Symptoms as follows:
engine management light on
When cold idle is up and down and sometimes starts on the second or third try.
When warm it's much better but not perfect.
Upon scanning I get the code: p0340 Camshaft Position sensor problem bank 1 (snap on solus machine)
The camshaft sensor that was in the car was a non genuine one so after doing some reading online into timing chain issues I decided it wouldn't do much harm to fit a genuine item.
The problem I have is, I have booked it into my mechanics who has done a few k12 micras before for a new chain and he says he is not convinced the chain is the issue
The timing chain area has absolutely no noise and the engine is quiet.
I was just wondering if anybody had any other ideas and also information on how to check the chain .
Does anybody know what is on the other side of the camshaft sensor i.e what it measures against?
Any other things to check?
Thank you very much for your help
