D
Deleted member 29304
Hi All,
I have only had this 2002 Micra tempest 3 days from a private seller & I find that the engine light came on during a day out. However I have one of those plug in meters to check whats wrong and it tells me that it is the 02 sensor circuit malfunction, Bank1 sensor 1. I know what you're thinking take it back to the people you brought from but it was from a private seller, but it could have gone at any time. I did notice when I had a closer look under the bonnet after buying it that one of the carbon black box connectors were not connected to anything and there was another tube also not connected to anything except leading down to engine, so this afternoon I made a heath robinson repair out of a clean water rubber tube and a pen ink cartridge-minus the ink. The cartridge acted as the tube connector inside the water rubber tubing then connected to the tube going to the engine and other end was connected to the fuel carbon box via duck tape, this repair is only a tempory one until I can find the proper tubing. Has anyone tried one of these OXYGEN LAMBDA O2 SENSOR FITS NISSAN MICRA K11 1.0, 1.4 etc via ebay for only £39.99 instead of £80 from Halfords?
Yours Peter0003
Yours Peter0003
