Hopefully someone will know the answer to what is causing a P0096 DTC on my Micra.
Car : 2017 Micra 1.5 dci
P0096 DTC code : "Intake air temperature (IAT) sensor 2 -circuit range/performance"
This really translates into the temperature that the IAT2 sensor is reporting to the ECU is not coherent with the temperature that the IAT sensor is reporting to the ECU.
The car has just been serviced (not by a main dealer), but the fault has not been cleared.
The car has had a new Airfilter, and a replacement MAF/IAT sensor, but no change.
Using Autodoctor Professional 7.0.1 for IOS, I believe that I've identified the likely cause of the P0096 code, but I'm now at a loss as to how to cure it.
The IAT2 temperature sensor reading is NOT reported by Autodoctor, but the IAT temperature is reported, and is wildly on the high side.
To eliminating any issues with heat soak, the car has been sat in my garage for 2 days, so the engine and all components are at ambient tempeature.
The Air Temperature sensor reports 20degree C (yes, its 20, and that is also what is displayed on the dash)
The IAT sensor that is combined with the MAF is reporting 55 degrees C - so about 35 degrees higher than it should be for a cold engine.
Assuming that IAT2 is reporting a reasonable temperature (circa 20 degrees) the massibe difference between IAT and IAT2 is causing the P0096 DTC.
Refitting the orignial MAF/IAT sensor gives the same reading, i.e. 55 degrees C.
Running the engine causes the reported temperature to rise slightly, and after a bit of heat soak, it hits about 60 degrees.
Disconnecting the MAF/IAT sensor gives P0113 - which indicates that the IAT sensor is open circuit.
This code clears as soon as the sensor is reconnected.
Cooling the IAT sensor with freezer spray does NOT reduce the reading by any significant amount.
I've reseated all the connectors between the sensor and the ECU and still no change.
I've disconnected that battery and left it disconnected for an hour and still no change.
Checking the behaviour of the same set of sensors on a Qashquai 1.5dci of a similar age gives a set of readings that are realastic, with an IAT of near ambient air temperature.
So the real question is, what is causing the IAT sensor to report such a high air temperature ?
Thanks in advance for any disagnostic suggestions.
