Overheating problem?
Changed the engine today from 1.0 to 1.3, an when I started it up the temperature gauge went up to hot, so changed thermostat an it's still the same anyone know what could be wrong ?
Havnt a clue yet? Started first turn after been lying up for nearly a year, not burning oil just think it's the water pump?
It's a actually running better than the engine I took out an that only had 46,000 miles, I just think it's the pump or a blockage somewhere
You sure it's not the temp sensor for the gauge. Does your fan come on when it gets hot as that's run from a different sensor via the ecu.
Fan doesn't come on no, engine doesn't really fell too hot either I'm gonna change the sensor as frank said they might be different rating on the jap engine
It was the temp sensor that fixed the gauge, but it still went up after a drive so changed the water pump and everything is perfect now :D
