CMF_Wheeltops
» CMF MemberYes - that old chestnut. I've been through all the old posts but I can't find an answer to my problem. We have a 1995/6 1.0L Micra and the old girl won't start. We have had the car for about three years and it had a bit of an issue with a misfire at high revs when we fist bought it but this seemed to improve with time. We were told at the time that it may have something to do with dry joints in the throttle body but re-soldering of the connections had no effect.
Anyhow, it ran fine up until a couple of weeks ago when I drove to work (a journey of some 20 miles down the motorway). I came out of work 8 hours later and the car started straight away (as normal) but after driving a few meters it cut out. I thought it was probably flooded so kept it turning over with the throttle wide open and after a minute or so it started up again. It would run at low revs but as soon as I pressed down on the throttle it wanted to stall. I drove about half a mile but then came to an gentle incline which required more gas and as soon as I tried to accelerate it just cut out. I called out the rescue services and they couldn't find anything obvious so they towed me home.
Now I asked around and the throttle body came up again so I replaced it. It still won't start. I have checked the spark and it seems ok the plugs are wet so there's juice getting through but it just won't fire.
I'm a bit old and have worked on plenty of cars with nice simple electrics and proper carburettors but this fuel injection system and electronic distribution unit have me baffled. What should I do next. I'd really appreciate some help from you guys.
Wheeltops
Wheeltops
