On my 'new' 89 micra someone has previously rigged up a bypass switch for the windscreen washer and separate wiring to and from the switch to the battery and pump, which works fine. Clearly something was wrong with the original set up, hence the bypass. I'd like to reinstate the original set up. Before I go digging, and spending money on a new wiper arm, does anyone know if there is a relay in the set up? Or is it wired straight to the pump, no doubt via a fuse. Cheers
