My sister has a 52 plate Micra Twister, but only has the one remote key with the car (also controls central locking).
It looks like this one http://img31.imageshack.us/i/micrakey.jpg/
Is it just a matter of getting a new/used one (with a new blade), then reprogramming it via this method?
"1. Place your key in the ignition and switch from the LOCK position to the ON position 6 times within 10 seconds ending with the key in the LOCK position
If done correctly the indicators should flash 2 times
2. Press and hold the UNLOCK button (black on P11) on your keyfob and while keeping it pressed then push the LOCK button (Red on P11) 3 times then release the UNLOCK button.
3. To reprogram a further key/keyfob remove the key and put your second key in the ignition (or hold your fob close to the ignition barrel) leaving it in the LOCK position and repeat step 2.
Once done turn your ignition on and then back off to exit the coding procedure."
Will this enable the central locking and the NATS immobiliser, or will the latter have to be programmed by a specialist?
Any suggestions for suppliers/programmers via the internet or around the Bristol area?
