CMF_micrafun2
» CMF MemberMy brake pedal is spongy after changing the front brake pads and discs.
I've done my brake bleed. But the pedal is still spongy. There may still be air in the system. Could not attach bleeder tube securely.
Just need some help with choosing a one man brake bleeder.
I am not a garage so I am not keen to buy an expensive brake bleeder.
I've seen the Mityvac. If it works, thats fine.
And some Sealey units VS020/VS0201.
Q1: Is there a budget unit you know works well for a one man brake bleed operation
Q2: Why do some people recommend you crimp the brake hose so that the brake fluid or air does not go into the master cylinder.
My brake hose is very stiff. Cannot be crimped. Is it really necessary to crimp the hose?
I dont understand where damage will occur if I dont crimp the brake hose - if I just push back the caliper cylinder with a G Clamp?
Any pointers will be appreciated
Danny
Danny
