I have searched aplenty and have found the greddy emanage ecu pinout.
My problem is excatly where the rpm marked my ecu has an empty hole with no wires running to it?
I run a 1996 LX and was wondering if for those ecu's it was somewhere else? I know that you can plug a super s cluster in and it should work which means the ecu does output RPM but which wire is it?
Cheers.
Cheers.
