Oil Sump Leak
Hi Everyone,
I've noticed today that my oil level was very low. After topping it up and doing general checks I noticed that my oil is dripping from the bottom of my engine / oil sump. What is the best way to fix this? My sump is extremely rusty, would there be anyway of fixing this easily or would I need to buy a new one?
Not a big job. Make sure you replace the gasket with it as well. I'd recommend coating it with stonechip as well. Easier when its on a bench so you don't get the stuff in your eye ;)
It has 2 gaskets by the way, not one.
They are sided so make sure you get them round the right way, also the sump gaskets have little locating lugs so make sure they are in right too!
