pork
Where im thinkimg of putting the turbo now, it may nit give the best oil drainage, it looks a litttle horizontal if you know what i mean, so, I may have to use a oil scavenger return pump, if this is the case, can I return the oil to wherever? Like, maybe even tap into the oil filler plug, or one of the breather ports on the rocker cover?
What pumps are best? What should else should I look out for?
