CMF_Marshal » CMF Member albury, nsw, Australia Member since: Posts: Nov 25, 2010 #1 well there is a preety constant drip comming from where the shaft connects to the gearbox, any ideas on how to fix it?
CMF_mycra » CMF Member melbourne, victoria, Australia Member since: Posts: Nov 25, 2010 #2 you should've taken it easy(complete disassemble) with the gear box when you did the clutch. your shaft seal is gone...couple dollars from burson.
CMF_Marshal » CMF Member albury, nsw, Australia Member since: Posts: Nov 25, 2010 #3 so i gotta drain the oil remove the shaft and replace the seal?
CMF_mycra » CMF Member melbourne, victoria, Australia Member since: Posts: Nov 26, 2010 #4 Marshal WROTE: "so i gotta drain the oil remove the shaft and replace the seal? Click to expand... that's a messy idea marshal don't listen to him.. The way you thought was perfect.
CMF_Marshal » CMF Member albury, nsw, Australia Member since: Posts: Nov 26, 2010 #5 is the drivers side the input or the diff side??
CMF_sikK11 » CMF Member Darwin, NT, Australia Member since: Posts: Nov 26, 2010 #6 Does not matter drain the oil or you will have a mess trust me I forgot to do it when I took them out lasttime.
CMF_Marshal » CMF Member albury, nsw, Australia Member since: Posts: Nov 26, 2010 #7 shes all fixed went to fill the oil in the box and forgot to put the plug back in the bottom so it was a mess!!
CMF_mycra » CMF Member melbourne, victoria, Australia Member since: Posts: Nov 26, 2010 #8 bahaaa...hey where you end up getting the seal??
CMF_Marshal » CMF Member albury, nsw, Australia Member since: Posts: Nov 27, 2010 #9 Well tryed everystore in town and then thought one last ditch attempt and repco had one
CMF_Mimz » CMF Member Melbourne, Vic, Australia Member since: Posts: Nov 27, 2010 #10 how much was it? im in the same process as well getting new clutch and my gearbox is out would u think its worth changing it just in case?
CMF_wadek11 » CMF Member mid north coast, NSW, Australia Member since: Posts: Nov 28, 2010 #11 yea may as well not very hard/expensive while you got the box out
CMF_fred » CMF Member Murwillumbah, nsw, Australia Member since: Posts: Dec 1, 2010 #12 just go a set $14 ea...
