Oil leaking from bottom of timing cover
I've noticed oil leaking from the bottom of cam belt timing cover. I've not looked yet but I suspect it may be from cam shaft oil seal, if so can I remove the seal and refit it from cambelt end without removing the cam-shaft etc.?
