Hi guys
Thought I'd help since I have been in the same situation.
My Super S has 3 of 4 spark plug tubes with oil in them, bought 3 replacement rocker covers and installed them but all but one kept the problem, so i had enough..
with one rocker cover i turned it around and found those spark plug tube seals and stuck a flat end screw driver carefully to prize them out.. got all of them out except one, i had to butcher the seal into pieces to help removed it.. they were out! with no damage to the seal recess! (need to be careful) after that i cleaned it all, and i got some seals from nissan (ill update with the part number once i am home) some motor factors provide them with the kit cant remeber the name but i have 2 sets available if needed.. pm me if you want
anyway once cleaned the recess i got some sealent and lined it in with my fingers and placed the new seals in (the right way round, remember to document which way round they go as i did but luckily i had 2 more useless rocker covers to go back to) placed the seals in, left for dry until the next day for all 4 seals and added a new gasket around the rocker cover and installed it.. didnt drive the car or even start it until 2 days later and since then NO OIL ever comes into the spark plug holes..
Even though they are bonded in the recess, they can be prized out carefully and a thin layer of sealant will stick the new seals in no problem
I have been driving my Super S for a year now after replacing them and no problems at all
Hope this helps guys and girls as i know annoying that problem was.
Peace
