Well I have had a leak for a little while (3mths) finally got off my a$$ to have a look, underneath the car is a mess! I had a look at the timing case, it's fine! Then found a small residue mark on my rocker cover and more wetness around the head next to the distributor, thought it could of been one of the sensor, but no! But then found a sh!t load of build up under the dizzy cap removed the cap only to find oil in it! I forgot who I brought it off, but they said it was rebuilt few weeks prior to me buying it! Should I pull it apart and check how oil is getting in? Replace the seal that sits on the dizzy under the rocker cover? Or just buy another?
Read some where it could possible be the o ring inside the rocker cover
