DEFIANTLY axle stands if you have to go under the car bud, once old filter is off dip a finger in new engine oil and smear it around the rubber sealing ring ( I always "prime" my new filter by filling it with oil too ) and refit hand tight only.
I just did this very same job on my Super S this weekend, it was the first oil change for the car in my possession ( I have owned it for about a month ) and my filter was very tight, so under the car with pipe grips I went, not much room to work and filter collapsed cause I had to grip it so hard, but eventually it came off. Refitted new filter hand tight, next oil change the filter should be "fairly" easy to remove from the engine bay rather than having to go under the car.
