Oil Catch Can..
CMF_sikK11
The filter let's it breath which I think is needed. Other wise it will just pressurize. There are ones out there that you can let drain back into the sump with A hole drilled but if it does not breath then this can pressurize the sump and this is less than ideal. Unless you are using oil etc I would leave it with the stock style setup.
CMF_sikK11
Will always have some oil deposits in there Kate. The stock setup is designed so the vapor and oil goes back into the engine and is burnt. So over the years it will leave oil all in the manifOld. Best bet if your worried is take it off and clean it all. Then refit and see how much is there in a week. Mine was exactly the same mate.
