Short version:
2002, 75K miles.
Clutch fine, linkage and spring good, gear oil good.
Gearbox loud, sometimes hard to select gears, worse when hot, 1st+2nd especially.
So my recently acquired K11 2002 may have a gearbox issue. A local mechanic had it but as an NCT (MOT) failure for corrosion. I test drove it a few times and liked it but noticed difficulty engaging gears sometimes. It would not grind but as if it could not fine the right slot to go into. He sorted the rust, greased the famous gear linkage and fixed the spring. It passed the test, I bought the car and gear change is better but still not perfect. The other day another mechanic I know checked it , says the clutch is perfect but the gearbox is very loud and ought to be replaced, though unlikely to go bang and leave me stranded. He could replacement it for €400, eek! The gearbox oil is fine and probably recently replaced, (maybe the original mechanic did that in an attempt to fix the gear change?). He said I could try flushing the gearbox with diesel. I feel the chap I bought the car from would not be inclined to fix the problem for free, even though it is a "pre-existing condition". I like the car, maybe I should just live with the way it is, I'll not be doing huge milage it it.
Cheers, thanks for any suggestions.
2002, 75K miles.
