Odd rumbling/vibration when braking?
capnmchl
Right, odd thing's been happening recently.
When ever I brake strongly from higher speeds, I can feel my far side front wheel sort of rumbling or vibrating quite a lot. It only seems to happen going down hill though.
I've had a look at the pads, and the disc, and they seem fine, the tyre has plenty of tread and it never happens at low speed or on flat/up hill.
Has anyone else had anything sort of like this?
Not really. They feel normal. Fluid looks all fine, but i guess that's no indication of air in the system, but I'm doing a service next month, so I'll bleed them then.
it could be the discs, not warped exactly but not a uniform thickness all around, you could try a swop left to right, or get someone to gently hold the brake on while you spin the wheel and feel for a tight spot eh :)
