Like it says in the title. I've been having some issues with the engine die-ing recently. These episodes have been predictably unpredictable. Though a couple of times I have had a repeat of the same issue, when starting from hot the revs pitch and drop, and any load on the engine will kill it completely, any throttle with make the pitching and dropping worse, but it will only rev to around 1500 before dropping again. I have replaced the very unpleasent looking fuel and air filters, and there's a dizzy cap and rotor arm to go on. Cleaning the fur off of the contact points in the dizzy and rotor tip seemed to have solved the problem, until a couple of days later when it started again - so I'm really hoping that the new cap solves the problem. But secretly I'm pretty sure its some of the black magic electrickery that keeps everything ticking along nicely until it decides to throw a wobbly.
So when the dizzy cap fails to solve the problem, what do you reckon I should try next?
