I realise this subject may have come up before, and have noticed it in a few threads I've looked through, my question is about obd scanners. Basically, for the uneducated heathen that I am in these matters, which type would be most useful to have, just in case a fault should rear it's head? I've had a look on eb*y and have seen them from anything around £15 upwards. Would a cheap one suffice or would I ideally be best going for a higher end model? Also do they give you a code if there are any stored faults or only if you start getting warning lights/issues? Excuse my naivety on the subject, I'm happier twirling spanners than on electrickery matters. All input gratefully received.
Hope you're all keeping well and getting the opportunity to get out to play or spanner to your hearts content.
