Nut Size & CV boots
CMF_penpusher
Cuppla questions
1st
Does anyone know the size of the large nut that is exposed when you remove the rim and that needs to be removed in order to remove the disc rotor/CV joint/s etc.
I want to buy a socket tomnorrow morning and don't know what size it is. 2nd
Is Repco the best place to buy a replacement CV joint boot kit ?
CMF_penpusher
You are a champ Rudy - the socket seems to be between a 29 and a 30 but it could be because of the shape of the socket as the 30mm is a bit loose but with the rattle gun it came off allright.
