As the thread title says, an even older friend and I fitted the original 160 SR springs that I got from Callum, along with a pair of Koni STR rear shock absorbers and at the same time I fitted a pair of hub centric 20mm rear wheel spacers.
Changing the rear springs and dampers is really quick and easy, but to change the front springs you have to remove the front struts completely, a bit more complicated, but if you have access to a couple of big trolley jacks, axle stands and a good spring compressor it's just time consuming.
The two of us (combined age 141) did the complete job, including an oil and filter change in under 4 hours, including a half hour stop for lunch.
What a difference it has made to the way it goes round corners now, taken out all of the wallowing and skipping on the rear end
Front:-
3/4 side:-
Side:-
and a close up of the rear wheel/arch :-
The 'Sports Suspension' springs have lowered the car by about 25mm and generally stiffened up the car, making it so much nicer to drive
Front:-
3/4 side:-
Side:-
