Transmission oil gearbox
Important: Not to be used in CVT units for which NS-1 or NS-2 fluid is prescribed.
1xAT-Matic D Fluid inc N-CVT (1-litre)
Hello boys and girls, I'm not for long time owner of 93 k11 1.0 automatic N CVT.
Car got some small probleem during 8 months i still want to keep it running.
I wanna change the CVT transmission fluid. How I'm diagnostic if is a NS 1 or NS 2 or whatever that means? Basically what oil should i use ? The OEM is abit expensive for Christmas.
I have the light on dashboard on for a week and mecanic advice to change the oil and filter.
Dose a 93' CVT transmission has a oil filter, where is located?
I noticed from P to D the light pops up on dashboard and the Idle rpm revs higher, what will cause this problem?
I have done a job, clean the distributor for corrosion.
The engine mount is broker the one on middle and cause shocks on deceleration at low speeds and probably affecting the transmission?
I need to reppace the engine mount middle, maybe we have some video photos tutorial?
Transmission oil and filter if is has one, what oil to use ?
Distributeur with a new one replaced.
I'm looking forward for your help thanks you in advance.
Maybe you can provide me some parts number if necessary.
