I've been enlisted to look at a colleague's preface that suddenly won't start. Initially it ran for around 3 seconds then died again, now there's nothing. No spark so I checked the dizzy, all dry and I sprayed with a water displacer just in case, still no start. The check engine light rapidly flashes and doesn't go off so I bridged the terminals and pulled the codes - Code 141 and 146. Checked the fuel injector fuse and holder but they're fine too. I'm starting to think it's a NATS issue but I can hear the fuel pump priming, would the pump prime if the ECU has gone pop or am I missing something
