It's a while since I posted here last, but I've got a new problem. My Micra won't start. It's an N reg 1.0l manual.
I had the AA out this morning, and he spent about 90 minutes working through things and in the end had to give up.
The car will turn over on the starter, but won't fire. We've confirmed that there's fuel going into the fuel rail (but none comes back out the return pipe). There's 12V at the injectors, and the injector fuse is good (I've had a problem in the past where the injector fuse had corroded). There's a good spark on the plugs.
We tried putting the ECU into diagnostic mode (short the two bottom-left pins on the diagnostic connector), but didn't get any lights flashing on the dashboard. We didn't manage to spot an LED on the ECU that the Haynes manual referred to.
Any suggestions on what to check for next? Is this likely to be an ECU problem, or a more simple electrical problem?
Thanks in advance,
Simon
Thanks in advance,
Simon
