No speedo & erratic fuel gauge
The speedo on my wifes micra (1 ltr, '98) stopped working last night.
I expected to find a loose connection but everything seems fine.
Also noticed that whilst driving the fuel gauge is moving from the level in the tank down to empty and then back and back down...
Temp gauge is reading normal.
Things I have check so far:
12V to speedo unit in gearbox OK (between yellow & black wire)
Gear on on of unit OK
Connection on back of instrument cluster OK
Can anyone tell me the output from the gearbox unit, is it mV, mA or something else, or if the fuel gauge and speedo can be in some way related ? perhaps an earth issue ??
The fuel gauge is only moving while the car is moving, therefore I think the speedo signal is somehow interfering with it ????
Many Thanks
Chris
Speedo fault identified !
Seperated the speedo drive unit and found the shaft between pinion and magnet had snapped, and all the plastic had melted.
Trip to scrap yard required :grinning:
Hi guys,
I think I have the exact same problem as CB_182.. have checked what he has said and seems identical. So i'm going to get a replacement speedo drive unit. (How much are they if I cant find 1 in scrappy?)
Also, I'm not exactly a mechanic.. but I can do the normal stuff like brakes etc.. how hard is this job going to be? I gotta get it done this weekend.
Look forward to some feedback.
cheers.
Hi, I paid £5 for one, not sure the guy new what it was or if it should have been anymore than that anyway.
Also, it was easy to do one bolt holds the unit in from above and then i carefully prised it up with a large screw driver from side to side.
P.S put a rag around it or on the floor as when it does pop out you will spill some oil.
hi CB 182, thanks for your reply.. Underneath the Engine there is 2 that look similar.. is the the once closest to the front of the car? or the one near the back of the gear box?
Having real trouble trying to find one at the moment, any ideas on where I can look?
sundog, the speedo drive is on the top of the diff (near the bulkhead) but you need to test whether the cable is spinning or not first (assuming yours is,nt digital) :)
Threada dead baby!
Anyway i have this problem, exact same symptoms.
Speedo failed and sits at 0mph. fuel gauge i can watch in real time going from half full to near empty.
Odometer has stopped working aswell. iv put another set of clocks in but no joy.
Any thoughts @frank
Its a 2000 W Reg K11, I believe its digital.
Digi speedo unit is on top of the gearbox, one 10mm bolt securing it. Once the bolt is out the unit can be quite stubborn to remove, I found using pliers/grips from the side, twisting gently a little in either direction while pulling upwards the unit would come out easily, yes watch out for a little seepage!
