I have a 54 reg mica. I haven’t used it for about a week, and when I tried to start it, it would not work.
It has keyless ignition and entry but I can’t even turn the ignition key manually, it’s like it’s locked itself.
There is no power at all can’t even lock/ unlock using the remote or use hazard lights which work even when the car is off.
I tried to jump start it but it’s still exactly the same.
now here’s the thing, there are a couple of weird things:
- The internal light had stopped working a long time ago and I just ignored it as the bulb is fine so it must be some other issue
- after the car stopped working I checked the fuse box and noticed that the “room lamp” fuse is blown
- I also noticed that in the fuse diagram it should be a 10 amp fuse, but the fuse in there is 7.5 amp (see attachments)
could this blown fuse be the cause for the car having 0 power? Or should I replace the battery? (The battery is still within its 3 year guarantee)
Many thanks
Many thanks
