NM of torque at flywheel?
hi, i changed my flyhweel on a 95 1.3 engine for a 1.0l and gearbox, i had looked up what pounds of torque to torque them and i was told 70 pounds of torque, i twisted my torque bar up to 70 and did the criss cross technique and torgued them up only to realise after gearbox and clutch went on i torqued them to 70NM instead my torque bar goes by nm not foot pounds
i did :
70 nm at flywheel with loctite
40nm at pressure plate with loctite
35 nm at bell housing
can anyone tell me if ill be ok or does it all need more torqing, thanks
cheers thats a relief , also theres a diferent connector coming off the reverse switch on the 95 gearbox to the 97 loom, it still connects in but is loose, would a bit of pvc tape holding it in do the job or do i need to solder old connector on?
the preface 1.0 g/box has a different rev/neutral plug eh, so you fitted the smaller 160mm clutch to a 1.3 ?
so just rewire the connectors? yeah i had a new clutch on my 1 litre so i used it and pressure plate one 1 l flywheel, is this wrong?
