Nissan pixo - brake bulb replacement
Hi
OK non Micra post!
My time to change a bulb on my girlfriend pixo.
How do you replace the brake bulb?
There don't seem to be any access from the rear. Do you have to take out the entire unit?
2 bolts I believe when you open the boot? Or behind the light unit itself. Maybe a bit tight once you've took the bolts off just be rough and careful at the same time ;)
