Hi everyone, long time no see. Just a quick one, i have been asked to look at a w reg micra not sure on engine size as of yet as i forgot to write it down. anyway, there is some trouble with the engine. Starting it up from cold takes a long time with turning the key. eventually it starts. But when you put your foot down to accelerate is slows the revs down. It doesnt die straight away but it does die if you keep your accelerator down. I know nothing about the newer model micra's so advice is much appreciated.
Oil level is fine.
Not checked spark plugs as i picked the car up tonight and its dark.
Air Filter is not clogged as i took box off to check if air filter was dirty.
Many Thanks
Oil level is fine.
Many Thanks
