hello
got a problem with my car
its a 54 2004 plate micra 1.2 se 3 door manual
the problem that i have with it is everytime a do a cold start in the morning, the car will start fine and idle a bit high like normal
then the revs will start to drop and then go back up again, the car has never cut out
it will only do this untill the car has warmed up, once worm the car doesnt want to cut out
the car has 90000 miles on it
i replaced the petrol camshaft oil sensor about 40000 miles as this had gone, the car would just cut out unless the throttle wasnt applied
i know everyone says timing chain but obivioulsy when i swapped the sensor the problem went away
i have had no dash lights on
could it be the RPM transmitter sensor that has gone or the air flow sensor
or is it the timing chain, if it was the timing chain i would have thought it would do it regardless if the car was warm or not
also the fuel enconomy is poor also, 100 miles for 20quid if im lucking
should i change the 02 sensor,lamba.or the fuel injectors?
i hope i make sense, many thanks for your help
in advance
in advance
