Nissan Micra 2006 K12 Automatic not starting
My Nissan K12 won’t start after I accidentaly sprayed anti mold product into the ignition lock.
It has a standard key (not keyless fob).
The lights turn on when I turn the key ON but when I further turn the car doesn’t start. A red symbol that is a key inside a car flashes very fast which didn’t before. I don’t hear any crank. Car battery is fully charged. Both keys have now new batteries. Some key programmers were getting P1611 code. But couldn’t get the car started either.
What do you suggest? If this is the immobiliser, is there a way to simply bypass it and start the car? Thanks for sharing your ideas and expertise.
Have you had the eps change. If someone has changed your eps and somehow fooled the car not to reset it could have bypassed the pairing. If since then you removed and reconnected the battery it would have reset. Where are you located?
Mmm, I don’t believe the NATS is in for an EU build. This might not be an eps issue. Hope you resolve it soon.
